Haas VF-2 Vertical Machining Centre
Haas VF-2 Specifications
X Axis 30"  762 mm
Y Axis 16"  406 mm
Z Axis 20"  508 mm
Spindle Nose to Table (~ max) 24"  610 mm
Length 36"  914 mm
Width 14"  356 mm
Max Weight on Table (evenly distributed) 3000lb  1361 kg
Rapids on X 1000in/min  25.4 m/min
Rapids on Y 1000in/min  25.4 m/min
Rapids on Z 1000in/min  25.4 m/min
Max Cutting 650in/min  16.5 m/min
Max Thrust X 2550lb  11343 N
Max Thrust Y 2550lb  11343 N
Max Thrust Z 4200lb  18683 N
Type Carousel (SMTC Optional)  Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2 sec  4.2 sec
Chip-to-Chip (avg) 4.5 sec  4.5 sec
Machine Weight 7300lb  3311 kg
