Haas VF-2SS Super Speed Vertical
Haas VF-2SS Specifications
X Axis 30 "  762 mm
Z Axis 20 "  508 mm
Spindle Nose to Table (~ max) 24 "  610 mm
Length 36 "  914 mm
Width 14 "  356 mm
Max Weight on Table (evenly distributed) 1500 lb  680 kg
Max Speed 12000 rpm  12000 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Cooling Liquid Cooled   Liquid Cooled
Rapids on X 1400 in/min  35.6 m/min
Rapids on Y 1400 in/min  35.6 m/min
Rapids on Z 1400 in/min  35.6 m/min
Max Cutting 833 in/min  21.2 m/min
Max Thrust X 1995 lb  8874 N
Max Thrust Y 1995 lb  8874 N
Max Thrust Z 3085 lb  13723 N
Capacity 24+1   24+1
Max Tool Diameter (adjacent empty) 5 "  127 mm
Max Tool Diameter (full) 3 "  76 mm
Max Tool Length (from gage line) 11 "  279 mm
Max Tool Weight 12 lb  5 kg
Tool-to-Tool (avg) 1.6 sec  1.6 sec
Chip-to-Chip (avg) 2.2 sec  2.2 sec
Machine Weight 8000 lb  3629 kg
