Haas VF-2TR 5-Axis Vertical Machining Centre
Machine may be shown with optional equipment.
Haas VF-2TR Specifications
X Axis 30"  762 mm
Y Axis 16"  406 mm
Z Axis 20"  508 mm
Spindle Nose to Table (~ max) 24"  610 mm
Length 36"  914 mm
Width 14"  356 mm
Max Weight on Table (evenly distributed) 3000lb  1361 kg
Rapids on X 1000in/min  25.4 m/min
Rapids on Y 1000in/min  25.4 m/min
Rapids on Z 1000in/min  25.4 m/min
Max Cutting 650in/min  16.5 m/min
Max Thrust X 2550lb  11343 N
Max Thrust Y 2550lb  11343 N
Max Thrust Z 4200lb  18683 N
TRUNNION S.A.E. Metric
Platter Diameter 6.3"  160 mm
Max Weight on Platter 80lb  36.3 kg
Max Part Swing (reduced at tilt angles > ± 90°) 17.5"  445 mm
T-Slot Width 0.625"  15.88 mm
Number of Std T-Slots 6
Pilot Bore Dia 1.500 (+0.0005, -0.0)"  38.10 (+ 0.013, –0.0) mm
Pilot Bore Depth 4.63"  117.6 mm
Rapids on A 4800°/min  4800 °/min
Rapids on B 4800°/min  4800 °/min
Max Cutting A 2000°/min  2000 °/min
Max Cutting B 2000°/min  2000 °/min
Max Tool Diameter (adjacent empty) 5.0"  127 mm
Max Tool Diameter (full) 3.0"  76 mm
Max Tool Length (from gage line) 11"  279 mm
Tool-to-Tool (avg) 2.8sec  2.8 sec
Chip-to-Chip (avg) 3.6sec  3.6 sec
Machine Weight 7725lb  3504 kg
