Haas VF-3SS Super Speed Vertical
Haas VF-3SS Specifications
X Axis 40"  1,016 mm
Y Axis 20"  508 mm
Spindle Nose to Table (~ max) 29"  737 mm
Length 48"  1,219 mm
Width 18"  457 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 1750lb  794 kg
Max Rating 30hp  22.4 kW
Max Speed 12,000rpm  12,000 rpm
Drive System Inline Direct Drive
Rapids on X 1400in/min  35.6 m/min
Rapids on Y 1400in/min  35.6 m/min
Rapids on Z 1400in/min  35.6 m/min
Max Cutting 833in/min  21.2 m/min
Max Thrust X 3085lb  13723 N
Max Thrust Y 3085lb  13723 N
Max Thrust Z 3923lb  17450 N
Max Tool Diameter (adjacent empty) 5"  127 mm
Max Tool Length (from gage line) 11"  279 mm
Tool-to-Tool (avg) 1.6sec  1.6 sec
Chip-to-Chip (avg) 2.2sec  2.2 sec
Power (options may increase requirement) 195-260 VAC/100 A
354-488 VAC/50 A
195-260 VAC/100 A
354-488 VAC/50 A
Machine Weight 12500lb  5670 kg
