Haas VF-3YT Vertical Machining Centre
Haas VF-3YT Specifications
X Axis 40"  1016 mm
Y Axis 26"  660 mm
Spindle Nose to Table (~ min) 4.5"  114 mm
Spindle Nose to Table (~ max) 29.5"  749 mm
Length 54"  1372 mm
Width 25"  635 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 3500lb  1588 kg
Max Torque 90 ft-lb @2000rpm  122 Nm @ 2000 rpm
Rapids on X 710in/min  18.0 m/min
Rapids on Y 710in/min  18.0 m/min
Rapids on Z 710in/min  18.0 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust X 2550lb  11343 N
Max Thrust Y 2550lb  11343 N
Max Thrust Z 4200lb  18683 N
Type Carousel (SMTC Optional)   Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2sec  4.2 sec
Chip-to-Chip (avg) 4.5sec  4.5 sec
Machine Weight 14000lb  6350 kg
