Haas VF-3YT/50 50-Taper Vertical
Haas VF-3YT/50 Specifications
X Axis 40 "  1016 mm
Y Axis 26 "  660 mm
Z Axis 25 "  635 mm
Spindle Nose to Table (~ min) 7.9 "  200 mm
Spindle Nose to Table (~ max) 32.9 "  836 mm
Length 52 "  1321 mm
Width 23 "  584 mm
T-Slot Center Distance 3.15 "  80.0 mm
Number of Std T-Slots 7   7
Max Weight on Table (evenly distributed) 4000 lb  1814 kg
Max Speed 7500 rpm  7500 rpm
Max Torque 450 ft-lb @ 500 rpm  610 Nm @ 500 rpm
Drive System 2-Speed Geared Head   2-Speed Geared Head
Taper CT or BT 50   CT or BT 50
Cooling Liquid Cooled   Liquid Cooled
Rapids on X 710 in/min  18.0 m/min
Rapids on Y 710 in/min  18.0 m/min
Rapids on Z 710 in/min  18.0 m/min
Max Thrust X 5600 lb  24910 N
Capacity 30+1   30+1
Max Tool Diameter (adjacent empty) 7 "  178 mm
Max Tool Diameter (full) 4 "  102 mm
Max Tool Length (from gage line) 16 "  406 mm
Max Tool Weight 30 lb  13.6 kg
Tool-to-Tool (avg) 4.2 sec  4.2 sec
Chip-to-Chip (avg) 6.3 sec  6.3 sec
Machine Weight 15900 lb  7212 kg
Click for CNC machines
