Haas VF-4 Vertical Machining Centre
Haas VF-4 Specifications
X Axis 50"  1270 mm
Y Axis 20"  508 mm
Spindle Nose to Table (~ max) 29"  737 mm
Length 52"  1321 mm
Width 18"  457 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 3500lb  1588 kg
Max Torque 90 ft-lb @2000rpm  122 Nm @ 2000 rpm
Max Torque w/opt Gearbox 250 ft-lb @1400rpm  339 Nm @ 450 rpm
Bearing Lubrication Air/Oil injection
Rapids on X 1000in/min  25.4 m/min
Rapids on Y 1000in/min  25.4 m/min
Rapids on Z 1000in/min  25.4 m/min
Max Cutting 650in/min  16.5 m/min
Max Thrust X 2550lb  11343 N
Max Thrust Y 2550lb  11343 N
Max Thrust Z 4200lb  18683 N
Type Carousel (SMTC Optional)   Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2sec  4.2 sec
Chip-to-Chip (avg) 4.5sec  4.5 sec
Machine Weight 13300lb  6033 kg
