Haas VF-4SS Super Speed Vertical
Haas VF-4SS Specifications
X Axis 50"  1270 mm
Y Axis 20"  508 mm
Spindle Nose to Table (~ max) 29"  737 mm
Length 52"  1321 mm
Width 18"  457 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 1750lb  794 kg
Max Rating 30hp  22.4 kW
Max Speed 12000rpm  12000 rpm
Rapids on X 1400in/min  35.6 m/min
Rapids on Y 1400in/min  35.6 m/min
Rapids on Z 1400in/min  35.6 m/min
Max Cutting 833in/min  21.2 m/min
Max Thrust X 3085lb  13723 N
Max Thrust Y 3085lb  13723 N
Max Thrust Z 3925lb  17459 N
Max Tool Diameter (adjacent empty) 5"  127 mm
Max Tool Length (from gage line) 11"  279 mm
Tool-to-Tool (avg) 1.6sec  1.6 sec
Chip-to-Chip (avg) 2.2sec  2.2 sec
Power (options may increase requirement) 195-260 VAC/100 A
354-488 VAC/50 A
195-260 VAC/100 A
354-488 VAC/50 A
Machine Weight 13300lb  6033 kg
