Haas VF-5 Vertical Machining Centre
Haas VF-5 Specifications
X Axis 50"  1270 mm
Y Axis 26"  660 mm
Spindle Nose to Table (~ min) 7.9"  200 mm
Spindle Nose to Table (~ max) 32.9"  836 mm
Length 52"  1321 mm
Width 23"  584 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 4000lb  1814 kg
Rapids on X 710in/min  18.0 m/min
Rapids on Y 710in/min  18.0 m/min
Rapids on Z 710in/min  18.0 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust Z 5600lb  24910 N
Type Carousel (SMTC Optional)  Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2sec  4.2 sec
Chip-to-Chip (avg) 4.5sec  4.5 sec
Machine Weight 14600lb  6623 kg
