Haas VF-5/40XT Vertical Machining Centre
Haas VF-5/40XT Specifications
X Axis 60"  1524 mm
Y Axis 26"  660 mm
Spindle Nose to Table (~ min) 7.9"  201 mm
Spindle Nose to Table (~ max) 32.9"  836 mm
Length 62"  1575 mm
Width 23"  584 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 4000lb  1814 kg
Max Rating 30hp  22.4 kW
Max Speed 7,500 rpm  7,500 rpm
Max Torque w/opt Gearbox 250 ft-lb @ 450 rpm  339 Nm @ 450 rpm
Rapids on X 540in/min  13.7 m/min
Rapids on Y 710in/min  18.0 m/min
Rapids on Z 710in/min  18.0 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust Z 5600lb  24910 N
Type Carousel (SMTC Optional)  Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2sec  4.2 sec
Chip-to-Chip (avg) 4.5sec  4.5 sec
Machine Weight 15150lb  6872 kg
