Haas VF-5SS Super Speed Vertical
Haas VF-5SS Specifications
X Axis 50"  1270 mm
Y Axis 26"  660 mm
Spindle Nose to Table (~ min) 7"  178 mm
Spindle Nose to Table (~ max) 32"  813 mm
Length 52"  1321 mm
Width 23"  584 mm
T-Slot Center Distance 3.15"  80.0 mm
Max Weight on Table (evenly distributed) 1750lb  794 kg
Max Rating 30hp  22.4 kW
Max Speed 12000rpm  12000 rpm
Drive System Inline Direct Drive  Inline Direct Drive
Rapids on X 1200in/min  30.48 m/min
Rapids on Y 1200in/min  30.48 m/min
Rapids on Z 1200in/min  30.48 m/min
Max Cutting 833in/min  21.2 m/min
Max Thrust X 3350lb  14902 N
Max Thrust Y 3350 lb  14902 N
Max Thrust Z 3350lb  14902 N
Capacity 24+1  24+1
Max Tool Diameter (adjacent empty) 5"  127 mm
Max Tool Diameter (full) 3.0"  76 mm
Max Tool Length (from gage line) 11"  279 mm
Tool-to-Tool (avg) 1.6sec  1.6 sec
Chip-to-Chip (avg) 2.2sec  2.2 sec
Power (options may increase requirement) 195-260 VAC/100 A
354-488 VAC/50 A
195-260 VAC/100 A
354-488 VAC/50 A
Machine Weight 14600lb  6623 kg
