Haas VF-5TR 5-Axis Vertical Machining Centre
Machine shown with optional equipment.
Haas VF-5TR Specifications
X Axis 38"  965 mm
Y Axis 26"  660 mm
A Axis (tilt) ±120°  ±120 °
B Axis (rot) 360°  360 °
Spindle Nose to Table (~ min) -0.85"  -21.6 mm
Spindle Nose to Table (~ max) 24.15"  613.4 mm
Rapids on X 710in/min  18.0 m/min
Rapids on Y 710in/min  18.0 m/min
Rapids on Z 710in/min  18.0 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust Z 5600lb  24910 N
TRUNNION S.A.E. Metric
Platter Diameter 8.3"  210 mm
Max Weight on Platter 200lb  90.7 kg
Max Part Swing (reduced at tilt angles > ± 90°) 23.5"  597 mm
T-Slot Width 0.625"  15.88 mm
Number of Std T-Slots 6
Pilot Bore Dia 2.000 (+0.0005, -0.0)"  50.80 (+ 0.013, –0.0) mm
Pilot Bore Depth 4.90"  124.5 mm
Rapids on A 3600°/min  3600 °/min
Rapids on B 3600°/min  3600 °/min
Max Cutting A 2000°/min  2000 °/min
Max Cutting B 2000°/min  2000 °/min
Capacity 24+1  24+1
Max Tool Diameter (adjacent empty) 6"  152 mm
Max Tool Length (from gage line) 16"  406 mm
Tool-to-Tool (avg) 2.8 sec  2.8 sec
Chip-to-Chip (avg) 3.6 sec  3.6 sec
Machine Weight 15400lb  6985 kg
