Haas VF-6SS Super Speed Vertical
Haas VF-6SS Specifications
X Axis 64"  1626 mm
Y Axis 32"  813 mm
Z Axis 30"  762 mm
Spindle Nose to Table (~ max) 34"  864 mm
Length 64"  1626 mm
Width 28"  711 mm
Max Weight on Table (evenly distributed) 2000lb  907.2 kg
Max Rating 30hp  22.4 kW
Max Speed 12,000rpm  12,000 rpm
Rapids on X 900in/min  22.9 m/min
Rapids on Y 1200in/min  30.5 m/min
Rapids on Z 1200in/min  30.5 m/min
Max Cutting 833in/min  21.2 m/min
Max Thrust Z 3400lb  15124 N
Max Tool Diameter (adjacent empty) 5"  127 mm
Max Tool Length (from gage line) 11"  279 mm
Tool-to-Tool (avg) 2.3sec  2.3 sec
Chip-to-Chip (avg) 3.2sec  3.2 sec
Power (options may increase requirement) 195-260 VAC/100 A
354-488 VAC/50 A
195-260 VAC/100 A
354-488 VAC/50 A
Machine Weight 21000lb  9526 kg
