Haas VF-7 Vertical Machining Centre
Haas VF-7 Specifications
X Axis 84"  2134 mm
Y Axis 32"  813 mm
Z Axis 30"  762 mm
Spindle Nose to Table (~ max) 34"  864 mm
Length 84"  2134 mm
Width 28"  711 mm
Max Weight on Table (evenly distributed) 4000lb  1814 kg
Rapids on X 600in/min  15.2 m/min
Rapids on Y 600in/min  15.2 m/min
Rapids on Z 600in/min  15.2 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust Z 5600lb  24910 N
Max Tool Diameter (adjacent empty) 6"  152 mm
Max Tool Length (from gage line) 16"  406 mm
Tool-to-Tool (avg) 2.8sec  2.8 sec
Chip-to-Chip (avg) 3.6sec  3.6 sec
Max Operating Depth 123"  3124 mm
Machine Weight 23000lb  10433 kg
