Haas VF-9/50 50-Taper Vertical
Haas VF-9/50 Specifications
X Axis 84 "  2134 mm
Y Axis 40 "  1016 mm
Z Axis 30 "  762 mm
Spindle Nose to Table (~ min) 5 "  127 mm
Spindle Nose to Table (~ max) 35 "  889 mm
Length 84 "  2134 mm
Width 36 "  914 mm
Number of Std T-Slots 7   7
Max Weight on Table (evenly distributed) 4000 lb  1814 kg
Max Speed 7500 rpm  7500 rpm
Max Torque 450 ft-lb @ 500 rpm  610 Nm @ 500 rpm
Drive System 2-Speed Geared Head   2-Speed Geared Head
Taper CT or BT 50   CT or BT 50
Cooling Liquid Cooled   Liquid Cooled
Rapids on X 600 in/min  15.2 m/min
Rapids on Y 600 in/min  15.2 m/min
Rapids on Z 600 in/min  15.2 m/min
Max Thrust X 3400 lb  15124 N
Capacity 30+1   30+1
Max Tool Diameter (adjacent empty) 10 "  254 mm
Max Tool Diameter (full) 4 "  102 mm
Max Tool Length (from gage line) 16 "  406 mm
Max Tool Weight 30 lb  13.6 kg
Tool-to-Tool (avg) 4.2 sec  4.2 sec
Chip-to-Chip (avg) 6.3 sec  6.3 sec
Max Operating Height 138 "  3505 mm
Max Operating Width 192.3 "  4884 mm
Max Operating Depth 139 "  3531 mm
Machine Weight 26500 lb  12020 kg
