Haas VM-2 The Mould Maker's Vertical
Haas VM-2 Specifications
X Axis 30 "  762 mm
Y Axis 20 "  508 mm
Z Axis 20 "  508 mm
Spindle Nose to Table (~ max) 24 "  610 mm
Length 36 "  914 mm
Width 18 "  457 mm
T-Slot Center Distance 4.375 "  111 mm
Number of Std T-Slots 7 in Y, 3 in X   7 in Y, 3 in X
Max Weight on Table (evenly distributed) 3000 lb  1361 kg
Max Speed 12000  rpm  12000 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Rapids on X 710 in/min  18.0 m/min
Rapids on Y 710 in/min  18.0 m/min
Rapids on Z 710 in/min  18.0 m/min
Max Thrust X 3400 lb  15124 N
Max Thrust Y 3400 lb  15124 N
Capacity 24+1   24+1
Max Tool Diameter (adjacent empty) 5.0 "  127 mm
Max Tool Diameter (full) 3.0 "  76 mm
Max Tool Length (from gage line) 11 "  279 mm
Tool-to-Tool (avg) 2.8  sec  2.8 sec
Chip-to-Chip (avg) 3.6  sec  3.6 sec
Machine Weight 7500 lb  3402 kg
