Haas VM-3 The Mould Maker's Vertical
Haas VM-3 Specifications
X Axis 40 "  1016 mm
Y Axis 26 "  660 mm
Z Axis 25 "  635 mm
Spindle Nose to Table (~ max) 29 "  737 mm
Length 54 "  1372 mm
Width 25 "  635 mm
T-Slot Center Distance 3.937 "  100.00 mm
Number of Std T-Slots 13 in Y, 6 in X   13 in Y, 6 in X
Max Weight on Table (evenly distributed) 4000 lb  1814 kg
Max Speed 12,000  rpm  12,000 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Rapids on X 710 in/min  18.0 m/min
Rapids on Y 710 in/min  18.0 m/min
Rapids on Z 710 in/min  18.0 m/min
Max Thrust X 5600 lb  24910 N
Capacity 24+1   24+1
Max Tool Diameter (adjacent empty) 5.0 "  127 mm
Max Tool Diameter (full) 3.0 "  76 mm
Max Tool Length (from gage line) 13 "  330 mm
Tool-to-Tool (avg) 2.8  sec  2.8 sec
Chip-to-Chip (avg) 3.6  sec  3.6 sec
Machine Weight 14000 lb  6350 kg
