Haas VM-6 The Mould Maker's Vertical
Haas VM-6 Specifications
X Axis 64 "  1626 mm
Y Axis 32 "  813 mm
Z Axis 30 "  762 mm
Spindle Nose to Table (~ max) 34 "  864 mm
Length 64 "  1626 mm
Width 28 "  711 mm
Number of Std T-Slots 5 in X , 12 in Y   5 in X , 12 in Y
Max Weight on Table (evenly distributed) 4000 lb  1814 kg
Max Speed 12000 rpm  12000 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Cooling Liquid Cooled   Liquid Cooled
Rapids on X 540 in/min  13.7 m/min
Rapids on Y 600 in/min  15.2 m/min
Rapids on Z 600 in/min  15.2 m/min
Max Thrust X 3400 lb  15124 N
Max Thrust Y 3400 lb  15124 N
Capacity 24+1   24+1
Max Tool Diameter (adjacent empty) 6 "  152 mm
Max Tool Diameter (full) 3 "  76 mm
Max Tool Length (from gage line) 16 "  406 mm
Tool-to-Tool (avg) 2.8 sec  2.8 sec
Chip-to-Chip (avg) 3.6 sec  3.6 sec
Max Operating Height 132.35 "  3362 mm
Max Operating Width 177.72 "  4514 mm
Max Operating Depth 123 "  3124 mm
Machine Weight 21000 lb  9526 kg
