SUPER MINI MILL
10k
The ALL NEW Super Mini Mill
Mini in Name.
Mighty in Performance.
Machine performance was once paired with size and cost. The Haas Super Mini Mill changed everything by packing 40-taper performance into a small package at unheard-of prices.
And now, we’re delivering even more value than ever before with increased travel, higher speeds, and more features.
Haas Mini Mills are the industry standard for compact machining centres. They are perfect for schools, start-up shops, or as a first step into CNC machining. Loaded with full-size features, they are valuable additions for shops needing a “second-op” machine or an additional spindle where space is limited.
Our Super Mini Mill Series machines are fully capable vertical mills, with many of the same components and options from our VF Series – but with smaller footprints.
You don’t need a huge space to make the most of your manufacturing capabilities. CNC machining doesn’t have to happen in a huge warehouse. Haas has proven that for more than 30 years.
Big upgrades, same compact footprint
Larger 406 x 356 x 381 mm travels
All-new FEA-optimized base and column castings
All-new external 170-litre coolant tank
Faster spindle speeds and rapids
Standard 30+1 side mount tool changer
Standard 10,000-rpm spindle (15k opt.)
Space-saving footprint
Increased spindle-nose-to-table clearance
All-new enclosure design with side windows
Lower table height for easy access
Heavier gauge waycovers for long life
Available auto door/window for easy automation
Rear Y-axis washdown nozzle for improved chip flow
We offer a wide selection of compact, affordable, easy-to-use CNC machines to fit any shop size or budget, whether you’re a start-up shop, taking your first step into CNC machining, or looking to bring your machining in-house.
FEA optimised castings
REDESIGNED to increase the overall rigidity and stability of the machine. The new castings are 30% heavier, but we only added material where needed, to increase performance without increasing cost.
Y-Axis washdown
The ALL-NEW Y-axis washdown nozzle flushes chips from the rear Y-axis waycover to prevent chip build-up behind the table during extended machining operations.
Side mount tool changer
NOW STANDARD on the Super Mini Mill, this Haas designed and built 30+1 side-mount tool changer provides more tools and faster tool changes, while freeing up the work envelope for larger fixtures and rotary tables.
External coolant tank
NOW STANDARD on all Mini Mills, the 45-gallon (170-litre) external coolant tank simplifies coolant maintenance and tank cleanout and provides additional coolant capacity.
Faster spindles and rapids
NOW STANDARD on the Mini Mill, our 8,000-rpm grease-packed spindle provides more rpm than the previous models, allowing higher feedrates and yielding more horsepower and torque for heavier cuts.
Side windows
Side windows are NOW STANDARD on all Mini Mills, providing additional access for job set-up and cleaning, as well as better visibility during machining. An available auto window makes it easy to add a Haas Cobot or APL for easy automation.
Please send me details:
  • United States+1
  • United Kingdom+44
  • Afghanistan+93
  • Albania+355
  • Algeria+213
  • American Samoa+1
  • Andorra+376
  • Angola+244
  • Anguilla+1
  • Antigua & Barbuda+1
  • Argentina+54
  • Armenia+374
  • Aruba+297
  • Ascension Island+247
  • Australia+61
  • Austria+43
  • Azerbaijan+994
  • Bahamas+1
  • Bahrain+973
  • Bangladesh+880
  • Barbados+1
  • Belarus+375
  • Belgium+32
  • Belize+501
  • Benin+229
  • Bermuda+1
  • Bhutan+975
  • Bolivia+591
  • Bosnia & Herzegovina+387
  • Botswana+267
  • Brazil+55
  • British Indian Ocean Territory+246
  • British Virgin Islands+1
  • Brunei+673
  • Bulgaria+359
  • Burkina Faso+226
  • Burundi+257
  • Cambodia+855
  • Cameroon+237
  • Canada+1
  • Cape Verde+238
  • Caribbean Netherlands+599
  • Cayman Islands+1
  • Central African Republic+236
  • Chad+235
  • Chile+56
  • China+86
  • Christmas Island+61
  • Cocos (Keeling) Islands+61
  • Colombia+57
  • Comoros+269
  • Congo - Brazzaville+242
  • Congo - Kinshasa+243
  • Cook Islands+682
  • Costa Rica+506
  • Croatia+385
  • Cuba+53
  • Curaçao+599
  • Cyprus+357
  • Czechia+420
  • Côte d’Ivoire+225
  • Denmark+45
  • Djibouti+253
  • Dominica+1
  • Dominican Republic+1
  • Ecuador+593
  • Egypt+20
  • El Salvador+503
  • Equatorial Guinea+240
  • Eritrea+291
  • Estonia+372
  • Eswatini+268
  • Ethiopia+251
  • Falkland Islands+500
  • Faroe Islands+298
  • Fiji+679
  • Finland+358
  • France+33
  • French Guiana+594
  • French Polynesia+689
  • Gabon+241
  • Gambia+220
  • Georgia+995
  • Germany+49
  • Ghana+233
  • Gibraltar+350
  • Greece+30
  • Greenland+299
  • Grenada+1
  • Guadeloupe+590
  • Guam+1
  • Guatemala+502
  • Guernsey+44
  • Guinea+224
  • Guinea-Bissau+245
  • Guyana+592
  • Haiti+509
  • Honduras+504
  • Hong Kong SAR China+852
  • Hungary+36
  • Iceland+354
  • India+91
  • Indonesia+62
  • Iran+98
  • Iraq+964
  • Ireland+353
  • Isle of Man+44
  • Israel+972
  • Italy+39
  • Jamaica+1
  • Japan+81
  • Jersey+44
  • Jordan+962
  • Kazakhstan+7
  • Kenya+254
  • Kiribati+686
  • Kosovo+383
  • Kuwait+965
  • Kyrgyzstan+996
  • Laos+856
  • Latvia+371
  • Lebanon+961
  • Lesotho+266
  • Liberia+231
  • Libya+218
  • Liechtenstein+423
  • Lithuania+370
  • Luxembourg+352
  • Macao SAR China+853
  • Madagascar+261
  • Malawi+265
  • Malaysia+60
  • Maldives+960
  • Mali+223
  • Malta+356
  • Marshall Islands+692
  • Martinique+596
  • Mauritania+222
  • Mauritius+230
  • Mayotte+262
  • Mexico+52
  • Micronesia+691
  • Moldova+373
  • Monaco+377
  • Mongolia+976
  • Montenegro+382
  • Montserrat+1
  • Morocco+212
  • Mozambique+258
  • Myanmar (Burma)+95
  • Namibia+264
  • Nauru+674
  • Nepal+977
  • Netherlands+31
  • New Caledonia+687
  • New Zealand+64
  • Nicaragua+505
  • Niger+227
  • Nigeria+234
  • Niue+683
  • Norfolk Island+672
  • North Korea+850
  • North Macedonia+389
  • Northern Mariana Islands+1
  • Norway+47
  • Oman+968
  • Pakistan+92
  • Palau+680
  • Palestinian Territories+970
  • Panama+507
  • Papua New Guinea+675
  • Paraguay+595
  • Peru+51
  • Philippines+63
  • Poland+48
  • Portugal+351
  • Puerto Rico+1
  • Qatar+974
  • Romania+40
  • Russia+7
  • Rwanda+250
  • Réunion+262
  • Samoa+685
  • San Marino+378
  • Saudi Arabia+966
  • Senegal+221
  • Serbia+381
  • Seychelles+248
  • Sierra Leone+232
  • Singapore+65
  • Sint Maarten+1
  • Slovakia+421
  • Slovenia+386
  • Solomon Islands+677
  • Somalia+252
  • South Africa+27
  • South Korea+82
  • South Sudan+211
  • Spain+34
  • Sri Lanka+94
  • St. Barthélemy+590
  • St. Helena+290
  • St. Kitts & Nevis+1
  • St. Lucia+1
  • St. Martin+590
  • St. Pierre & Miquelon+508
  • St. Vincent & Grenadines+1
  • Sudan+249
  • Suriname+597
  • Svalbard & Jan Mayen+47
  • Sweden+46
  • Switzerland+41
  • Syria+963
  • São Tomé & Príncipe+239
  • Taiwan+886
  • Tajikistan+992
  • Tanzania+255
  • Thailand+66
  • Timor-Leste+670
  • Togo+228
  • Tokelau+690
  • Tonga+676
  • Trinidad & Tobago+1
  • Tunisia+216
  • Turkey+90
  • Turkmenistan+993
  • Turks & Caicos Islands+1
  • Tuvalu+688
  • U.S. Virgin Islands+1
  • Uganda+256
  • Ukraine+380
  • United Arab Emirates+971
  • United Kingdom+44
  • United States+1
  • Uruguay+598
  • Uzbekistan+998
  • Vanuatu+678
  • Vatican City+39
  • Venezuela+58
  • Vietnam+84
  • Wallis & Futuna+681
  • Western Sahara+212
  • Yemen+967
  • Zambia+260
  • Zimbabwe+263
  • Åland Islands+358
