JOIN US AT THEAIR TURBINE SPINDLES SPECIAL EVENT.
  • Hethel Engineering Centre
  • Norfolk • NR14 8FB
  • Tuesday 23rd & Wednesday 24th July
  • 9:00 - 17:00
See the latest Haas CNC machines cutting metal using Air Turbine Spindles. Now, your Haas Machine will mill from 25,000 to 90,000 rpm with power to 1.4HP! See for yourself in these live demonstrations that you don't need to sacrifice power to get high speed.
Call Rebecca on 01603 760539 or email rgrodentz@haas.co.uk to book your spaces.
ADVANTAGES OF USING AIR TURBINE SPINDLES
• Constant High Speed and Torque in cut
• Vastly reduced cycle times and improved surface finishes
•  Low Heat. No Duty Cycle. No thermal effects on accuracy
• Fully Automated Loading with the Tool-changer Assembly
• Through Spindle Air Option using Haas Through Tool Air Blast
• Higher machining speeds with tools 0.1 mm up to 6.0 mm (1/4”)
• Speeds that don’t drop on your toolpath optimise tool performance
• Increase feed rates using High Speed Machining software
• Just 90 PSI needed. No control system, gears or HF brushes
Air Turbine Spindle milling at governed 65,000rpm on Haas CNC
Norfolk
NR14 8FB
23 July 2019
9:00 - 17:00
24 July 2019
9:00 - 17:00
