ER-11 Collet
Taper
15K rpm
Spindle
220 V
Single Phase
The Haas Desktop Mill is the ultimate training machine for schools and technical colleges. Powered by a full-function Haas CNC control housed in our portable simulator enclosure, the Desktop Mill is perfect for teaching the basic principles of programming and operating a CNC mill. Designed to cut plastics and machinable wax, it is also perfect for hobbyists and benchtop machinists.
CNC Pen Holder: Converts the Desktop Mill into a CNC plotter, for drawing, proofing toolpaths, and teaching CNC programming.
Available software package: High-Speed Machining, Haas Visual Programming System, User-Definable Macros, and Coordinate Rotation & Scaling.
NOTE: Running the spindle slower than 1500 rpm can cause the spindle to overheat.
N.B. Specifications subject to change without notice.
TRAVELS | S.A.E | METRIC |
X Axis | 6.00 in | 152 mm |
Y Axis | 10.00 in | 254 mm |
Z Axis | 3.00 in | 76 mm |
Spindle Nose to Table (~ max) | 3.2 in | 80 mm |
SPINDLE | S.A.E | METRIC |
Max Speed | 15000 rpm | 15000 rpm |
Drive System | Integral Spindle/Motor | Integral Spindle/Motor |
Taper | ER11 Collet | ER11 Collet |
TABLE | S.A.E | METRIC |
Length | 18.1 in | 460 mm |
Width | 10.6 in | 270 mm |
The Haas Desktop Mill is a portable CNC machine geared toward the education and hobbyist market. It is perfect for learning the fundamentals of CNC programming, right on the industry-leading Haas control. Operate and program a fully functioning Haas CNC machine, right on your desktop.
Aimed at the education sector, as well as the benchtop machinist, the Desktop Mill combines a full-featured Haas control with a desktop-sized machine to create the perfect package for both teaching and learning the basics of CNC programming and operation.
The Desktop Mill is perfect for teaching the basic principles of programming and operating a CNC mill.
With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your CNC program!
We’re here to answer all of your questions about adding a Desktop Mill or Desktop Lathe to your classroom or workshop.
For details email us, or call 01603 760539.
