HC-10 Cobot
10 kg
Capacity
157 mm
Max Part Dia.
1000 mm
Reach
6
All-in-one cobot kit for your new machine! The Haas 10 kg Cobot Package includes everything required to run your new cobot directly from the Haas control. This kit features the HC10 Cobot with a 10 kg capacity, dual pneumatic grippers, protective barriers, a temporary mounting base*, a parts table, a part flip station, and all necessary hardware and cables.
10 KG CAPACITY | 1000 MM REACH
AVAILABLE ON: Small VFs, ST-10 through ST-28, DTs, DMs, DC-1, DC-2, Mini Mills, UMC-400/SS, and UMC-500/SS
*Does not ship pre-built. The temporary mounting base is for optional use, and is not included in Europe. Floor mounting is recommended. Cobot carries a one-year warranty.
ROBOT & COBOT PACKAGES
7 kg Robot
25 kg Robot
50 kg Robot
5 kg Cobot
10 kg Cobot
15 kg Cobot
HC-10 Specifications
N.B. Specifications subject to change without notice.
SEE HAAS COBOTS IN ACTION
Haas Robot Packages - Overview
Alex walks us through programming a complete part setup on the Haas HC10 Cobot. The Haas HC10 is a fully integrated, plug-and-play, 10kg capacity collaborative robot for Haas machines.
Haas Cobots - Choosing the Right Platform
Mike introduces Haas’ new Cobot Kit! You get absolutely amazing value when you purchase this kit along with a new machine. The Haas all-in-one Machine Ready Cobot kit includes everything required to run your new Cobot right off the Haas control.
Fast Easy Automation
There’s never been an easier way to add a 6-axis robot to a Haas machine. With Haas Robot Packages, you set up and control the robot directly from the Haas control, with no need for complex PLC connections or a 3rd-party integrator.
Automated Machining Cell VS Manually Loaded
Check out this animated infographic that shows the potential output increase and labor hours decrease when switching to an automated cobot loaded cell from a manually loaded machining cell.
We’re here to answer all of your questions about adding a Robot or Cobot to your shop.
For details email us, or call 01603 760539.
quick reply form
Do you need funding?
Talk to our dedicated team
