7 kg
Capacity
911 mm
Reach
157 mm
Max Part Dia.
6
The Haas Robot Package 1 is a fully integrated, plug-and-play, 7 kg capacity robot system for Haas machines. The system is controlled entirely from the Haas control. Includes: 6-axis robot, mounting stand, software interface for direct control through the Haas machine, electrical interface box, safety guarding, and all necessary solenoids, hardware, and cables.
7 kg Max Capacity (part + gripper)
N.B. Specifications subject to change without notice.
Axes | S.A.E | METRIC |
Controlled Axes | 6 | 6 |
Capacities | S.A.E | METRIC |
Max Load Capacity at Wrist | 15.4 lb | 7 kg |
Reach | 35.9 in | 911 mm |
Repeatability | 0.0004 in | 0.010 mm |
Single Gripper | S.A.E | METRIC |
Max Part Weight | 7.9 lb | 3.6 kg |
Gripper Assembly Weight | 7.5 lb | 3.4 kg |
Part Size - Round ø | 0.63 in to 6.20 in | 16 mm to 157 mm |
Part Width - Rectangular | 0.38 in to 6.00 in | 10 mm to 52 mm |
Part Length - Rectangular | 0.90 in to 2.20 in | 23 mm to 56 mm |
Dual Gripper | S.A.E | METRIC |
Max Part Weight (per gripper) | 2.5 lb | 1.1 kg |
Gripper Assembly Weight | 7.0 lb | 3.2 kg |
Part Size - Round ø | 1.00 in to 6.00 in | 25 mm to 152 mm |
Part Width - Rectangular | 0.75 in to 6.25 in | 19 mm to 158 mm |
Part Length - Rectangular | 0.90 in to 1.65 in | 23 mm to 42 mm |
Motion | S.A.E | METRIC |
Motion Range – J1 | 340 ° | 340 ° |
Motion Range - J2 | 245 ° | 245 ° |
Motion Range - J3 | 430 ° | 430 ° |
Motion Range - J4 | 380 ° | 380 ° |
Motion Range - J5 | 250 ° | 250 ° |
Motion Range - J6 | 720 ° | 720 ° |
Speeds | S.A.E | METRIC |
Max Speed - J1 | 370 °/sec | 370 °/sec |
Max Speed - J2 | 310 °/sec | 310 °/sec |
Max Speed - J3 | 410 °/sec | 410 °/sec |
Max Speed - J4 | 550 °/sec | 550 °/sec |
Max Speed - J5 | 545 °/sec | 545 °/sec |
Max Speed - J6 | 1,000 °/sec | 1,000 °/sec |
Dimensions - Shipping | S.A.E | METRIC |
Domestic Pallet | 67.0 in x 47.0 in x 68.0 in | 170 cm x 119 cm x 173 cm |
Export Pallet | 67.0 in x 47.0 in x 68.0 in | 170 cm x 119 cm x 173 cm |
Export Crate | 67.0 in x 49.0 in x 77.0 in | 170 cm x 124 cm x 196 cm |
Weight | 720 lb | 326.6 kg |
Domestic Crate for Safety Fence | 79.0 in 55.0 in 34.0 in | 201 cm 140 cm 86 cm |
Export Crate for Safety Fence | 79.0 in 55.0 in 34.0 in | 201 cm 140 cm 86 cm |
Weight for Safety Fence Crate | 660 lb | 299.0 kg |
What do you get when you combine our small footprint ST-10Y turning centre with our 7 kg robot? The ability to run complex parts unattended all inside a small chunk of real estate.
Haas has three different Plug & Play Robot packages of varying sizes. In this video, we look at each of the three robot packages; what you get in the package, their capacity and reach, and the machines that each package will fit.
There’s never been an easier way to add a 6-axis robot to a Haas machine. With Haas Robot Packages, you set up and control the robot directly from the Haas control, with no need for complex PLC connections or a 3rd-party integrator.
When you get a Haas Robot Package you get a Plug & Play system that is ready to go out of the gate. Manufacturing Engineer Mallory Tevini gives us a bunch of great examples of ways you can make your robot cell fit your shop’s circumstances perfectly.
We’re here to answer all of your questions about adding a Robot or Cobot to your shop.
For details email us, or call 01603 760539.
