The industry-leading Haas VFs are the best-value, high-performance vertical machining centres available today.
A Wide Range of Sizes and Features to Fit Any Shop’s Needs – Vertical Machining Centres
Haas offers a wide range of VF Series CNC vertical machining centres to match any size and production requirement. Regardless of your needs, there’s a VF just right to meet the demands of your machine shop.
Every VF Series vertical machining centre provides outstanding features at an excellent price. By the same token there are a wide range of available options to customise your machine to your exact needs. Not to mention all Haas machines are designed and built in California, USA.
The VF-6/40 is the first of our large-frame 40-taper VMCs. These models come with an upgraded features package that includes a side-mount tool changer, chip auger, programmable coolant nozzle, and remote jog handle.
- High-power direct-drive spindles
- Customisable to your needs
- Upgraded standard features package
VF-6 Vertical Machining Centre; 1626 x 813 x 762 mm, 40 taper, 30 hp vector drive, 8100 rpm, direct-drive, 30+1 side-mount tool changer, 15.2 m/min rapids, automatic chip auger, programmable coolant nozzle, colour remote jog handle, power-failure detection module, 1 GB program memory, 15″ colour LCD monitor, USB port, Ethernet, memory lock keyswitch, rigid tapping and a 360 litre flood coolant system.
Haas Vertical Machining Centres and Rotary Tables – A Perfect Combination
Haas got its start making rotary tables and indexers that helped milling machines make more kinds of parts. So it makes perfect sense that Haas rotary products work seamlessly with our milling machines.
Here we take a quick look at just a few examples of how our machine and rotary combinations can help you get your difficult multi-sided parts done better.
Automate your high-speed machine’s setup process with the Haas Wireless Intuitive Probing System (WIPS). WIPS is a complete probing package that includes the spindle probe, tool setting probe, and optical machine interface. Furthermore, powerful software that guides the operator through the job setup process with intuitive, easy-to-use templates. WIPS allows you to quickly and easily define work offset coordinates. Additionally, set tool length offsets, and perform in-process inspection.
